It is currently Mon Sep 15, 2025 8:45 am
Post new topic Reply to topic  [ 1839 posts ]  Go to page Previous  1 ... 59, 60, 61, 62, 63, 64, 65 ... 74  Next
PostPosted: Sat Jul 27, 2024 12:38 pm
That's got to be weird working in 3 dimensions with changing radiuses on surfaces. I bet your first time was nerve racking.
PostPosted: Sat Jul 27, 2024 12:52 pm
First name: Ken
Last Name: Nagy
City: Goodrich
Chris, a lot of the time I'm working on curves with a flat plane blade. You just tilt it different ways. Like putting a compound radius on a fretboard, and adding relief at the same time. Or smoothing out neck heels. It would have helped if I had something to look at when I made them! This one is just from 2 photos that don't show the arch at all.
But now that I'm a wood listener...
You see it. You can feel it. You can hear the high spots when you tap. Only in thicknessing do I ever measure anything. Setting up the outside recurve gets a lot of the fiddly stuff out of the way.
Why be normal?
These users thanked the author Ken Nagy for the post: Chris Pile (Sat Jul 27, 2024 3:06 pm)
PostPosted: Tue Jul 30, 2024 5:33 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Inside the sides of the mandocello that I'm building.
These users thanked the author J De Rocher for the post (total 5): Craig Wilson (Wed Jul 31, 2024 4:51 am) • SteveSmith (Tue Jul 30, 2024 7:29 pm) • Ken Nagy (Tue Jul 30, 2024 6:16 pm) • rbuddy (Tue Jul 30, 2024 5:50 pm) • bcombs510 (Tue Jul 30, 2024 5:45 pm)
PostPosted: Tue Jul 30, 2024 5:46 pm
First name: Brad
Last Name: Combs
That looks awesome, Jay!
I’m done with mold building and time to bend sides tonight! This is the design with the zip bolts closure that I showed at the roundtable a couple months ago.
Brad
These users thanked the author bcombs510 for the post (total 4): Kbore (Wed Jul 31, 2024 12:11 pm) • Craig Wilson (Wed Jul 31, 2024 4:51 am) • SteveSmith (Tue Jul 30, 2024 7:30 pm) • doncaparker (Tue Jul 30, 2024 6:27 pm)
PostPosted: Wed Jul 31, 2024 8:43 pm
First name: Brad
Last Name: Combs
Here is an add-on for the mold to bring it to the height of the blocks during glue up. This uses the pins and hole liners I showed at the roundtable recently.
Here’s a demo:
https://www.instagram.com/reel/C-G9g3RO ... FwdGp5NnJ5
Brad
These users thanked the author bcombs510 for the post (total 2): Hesh (Mon Aug 05, 2024 11:13 am) • SteveSmith (Thu Aug 01, 2024 8:14 am)
PostPosted: Thu Aug 01, 2024 12:49 pm
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Brad
I like that! I may switch mine to this configuration.
Sent from my SM-A546V using Tapatalk
Hutch
These users thanked the author banjopicks for the post: bcombs510 (Thu Aug 01, 2024 1:03 pm)
PostPosted: Fri Aug 02, 2024 9:08 pm
I can't remember if I've ever mentioned this one.... About 5 years ago I bought an Eddie Finn 8 string uke. I know what you're saying, "PILE! You hate ukes!". Yes, I do - but I bought this one for a reason. The nut is 1 3/4" wide, not a little toothpick. And I converted it to a mandola. The scale is 17", just right for a tenor mandola, and with the wider neck I can easily play it. A lot of people told me it wouldn't hold steel strings - too much pressure. I knew better. It's been loaned out to family and friends in the last 5 years, and finally came back to me. It was drying out a bit, but I took care of the fret ends... and yes, the wings of the bridge were starting to lift. Easy fix for both. Decided to add a mandolin tailpiece to move the tension to the tailblock, and since the cheap 4 on a plate tuners weren't staying in tune, I ordered some nice Gotoh uke tuners - singles, with adjustable length posts. WHY? Because it's a slotted peghead. BEHOLD! Fresh strings, solid tuning machines a shiny tailpiece. It's SWEET. Would I kid you?
https://imgur.com/a/MHWiweD
These users thanked the author Chris Pile for the post (total 7): Ken Nagy (Tue Aug 06, 2024 5:51 am) • Hesh (Mon Aug 05, 2024 11:14 am) • Kbore (Sun Aug 04, 2024 8:37 pm) • Durero (Sat Aug 03, 2024 3:24 pm) • SteveSmith (Sat Aug 03, 2024 1:44 pm) • J De Rocher (Sat Aug 03, 2024 1:23 pm) • bcombs510 (Fri Aug 02, 2024 9:13 pm)
PostPosted: Mon Aug 05, 2024 8:24 pm
First name: Brad
Last Name: Combs
Working on the double sides. Fingers crossed!
Brad
These users thanked the author bcombs510 for the post (total 8): SteveSmith (Tue Aug 06, 2024 6:55 am) • Ken Nagy (Tue Aug 06, 2024 5:52 am) • Hesh (Tue Aug 06, 2024 4:30 am) • Colin North (Tue Aug 06, 2024 1:55 am) • Durero (Mon Aug 05, 2024 11:44 pm) • Kbore (Mon Aug 05, 2024 9:35 pm) • J De Rocher (Mon Aug 05, 2024 8:58 pm) • Chris Pile (Mon Aug 05, 2024 8:26 pm)
PostPosted: Thu Aug 08, 2024 6:15 pm
First name: Brad
Last Name: Combs
Feels a little like cheating….
Brad
These users thanked the author bcombs510 for the post (total 5): Kbore (Fri Aug 09, 2024 10:59 am) • Colin North (Fri Aug 09, 2024 1:36 am) • doncaparker (Thu Aug 08, 2024 9:30 pm) • Durero (Thu Aug 08, 2024 7:57 pm) • Chris Pile (Thu Aug 08, 2024 7:39 pm)
PostPosted: Fri Aug 09, 2024 8:51 am
Just finished building a "knock down" spray booth for spraying water based Crystalac Britetone. It can be easily disassembled by unclipping the 4 bedframe brackets for headboards and footboard. The dimensions are 48" Tall/20" deep/24" wide with a 16” x 20” 8 Merv furnace filter. The box at the back is fit to the opening with an 8-inch duct that connects to flexible hose with a 1000 CFM exhaust fan that will draw the overspray out of my tiny garage.
These users thanked the author Anthony Z for the post (total 3): Chris Pile (Fri Aug 09, 2024 1:18 pm) • Treenewt (Fri Aug 09, 2024 12:13 pm) • Kbore (Fri Aug 09, 2024 11:02 am)
PostPosted: Fri Aug 09, 2024 8:54 am
Here is what is close to being ready to be finished.
These users thanked the author Anthony Z for the post (total 4): Ken Nagy (Sat Aug 10, 2024 6:40 am) • Chris Pile (Fri Aug 09, 2024 1:18 pm) • Kbore (Fri Aug 09, 2024 11:02 am) • bcombs510 (Fri Aug 09, 2024 9:54 am)
PostPosted: Fri Aug 09, 2024 11:43 am
Most expensive guitar I've ever had in my shop for work. This one will not stay in my shop overnight!
I may even sleep with it...ImageImage
Sent from my moto g(50) using Tapatalk
These users thanked the author Colin North for the post (total 7): Ken Nagy (Sat Aug 10, 2024 6:42 am) • Kbore (Fri Aug 09, 2024 11:01 pm) • Hesh (Fri Aug 09, 2024 5:39 pm) • SteveSmith (Fri Aug 09, 2024 1:56 pm) • Chris Pile (Fri Aug 09, 2024 1:17 pm) • Treenewt (Fri Aug 09, 2024 12:13 pm) • bcombs510 (Fri Aug 09, 2024 11:58 am)
PostPosted: Fri Aug 09, 2024 11:06 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Use a modified JJ method for cutting the tenon and cheeks, my first.
I like it.
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post (total 2): Ken Nagy (Sat Aug 10, 2024 6:43 am) • bcombs510 (Sat Aug 10, 2024 6:18 am)
PostPosted: Sun Aug 11, 2024 1:06 pm
First name: Brad
Last Name: Combs
A few shots of making solid mahogany lining.
https://youtube.com/shorts/QFbk9lub2n8? ... HtDDw_leiy
PostPosted: Sun Aug 11, 2024 1:46 pm
First name: Karl
Last Name: Borum
Great video Brad!
Did you make the paper roll dispenser?
I need to get/ make one! THey are kind of pricey to buy.
Measure Twice,
Karl Borum
PostPosted: Sun Aug 11, 2024 6:16 pm
First name: Brad
Last Name: Combs
We got it from a school supply company locally I believe. My wife is a teacher, they know where to buy all the art supplies. ;)
Here is a short video of plate prep before bracing. Finally getting to put an instrument through the paces of a complete(ish) build system.
https://youtube.com/shorts/3od1kxDIeVQ? ... nsbHQnsznc
These users thanked the author bcombs510 for the post: Kbore (Sat Aug 17, 2024 1:41 am)
PostPosted: Sun Aug 11, 2024 8:30 pm
I have a couple ready to go to the store. The Rosewood is my first with a Cedar top. Jim Olson gave me three back in 2020 (they had micro defects he said he couldn’t put on an 40K guitar :))and I finally got around to using one. I thicknessed it to the same deflection I use for spruce.
It is a double side with a Maple inner.
As I am a few months shy of 80 I don’t trust my hearing that much anymore but the Cedar has gotten good reviews from a couple of pros. The Maple has a rosewood inner side. That has been a good combo with Maple.
These are 90 and 91. I hope to hit 100 before I am unable to build anymore. I am optimistic.
ImageIMG_9353 by Terence Kennedy, on Flickr
ImageIMG_9354 by Terence Kennedy, on Flickr
These users thanked the author Terence Kennedy for the post (total 6): Anthony Z (Mon Aug 12, 2024 12:02 pm) • Ken Nagy (Mon Aug 12, 2024 5:33 am) • Hesh (Mon Aug 12, 2024 5:11 am) • Colin North (Mon Aug 12, 2024 2:55 am) • Kbore (Sun Aug 11, 2024 10:48 pm) • bcombs510 (Sun Aug 11, 2024 8:57 pm)
PostPosted: Mon Aug 12, 2024 4:38 pm
First name: Karl
Last Name: Borum
Beautiful guitars. Guess you will have to lower the price to 30K. I'm rooting for #100!
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post (total 2): bcombs510 (Mon Aug 12, 2024 8:25 pm) • Terence Kennedy (Mon Aug 12, 2024 8:12 pm)
PostPosted: Mon Aug 12, 2024 8:25 pm
First name: Brad
Last Name: Combs
Lovely, Terry!
Here is how the lining turned out. Russian nesting dolls!
https://youtube.com/shorts/oNU_v8xZQcI? ... qb-RCUY92Q
Brad
These users thanked the author bcombs510 for the post (total 2): Kbore (Tue Aug 13, 2024 4:46 pm) • Terence Kennedy (Mon Aug 12, 2024 10:34 pm)
PostPosted: Tue Aug 13, 2024 5:09 am
A special congratulations to you Terry for approaching 100 guitars. That's quite an accomplishment and I never made it that far stopping at 54 1/2. Your guitars are excellent too as indicated by the fact that I never saw one :) Congratulations my friend!!!
These users thanked the author Hesh for the post (total 2): Kbore (Tue Aug 13, 2024 4:46 pm) • Terence Kennedy (Tue Aug 13, 2024 9:04 am)
PostPosted: Tue Aug 13, 2024 1:26 pm
This is a classical guitar that I built in 1978. It has been sitting in a cabinet for several decades because the action was too high. The neck was joined as a butt joint with a 1/8" thick maple spline. I decided to get it repaired which necessitated a bolt-on neck conversion. One new thing I tried was Master Shield by Glu-Boost to protect the sides during the cut. Also used a very thin Japanese flush cut saw. Pretty happy with the way it turned out.
These users thanked the author Barry Daniels for the post (total 3): Kbore (Tue Aug 13, 2024 4:47 pm) • Terence Kennedy (Tue Aug 13, 2024 3:41 pm) • bcombs510 (Tue Aug 13, 2024 1:54 pm)
PostPosted: Tue Aug 13, 2024 6:28 pm
First name: Jay
City: Bothell
State: Washington
Finished up a simple rosette with a maple ring and maple soundhole binding.
These users thanked the author J De Rocher for the post (total 4): rbuddy (Wed Aug 14, 2024 4:30 pm) • bcombs510 (Tue Aug 13, 2024 8:10 pm) • Kbore (Tue Aug 13, 2024 7:05 pm) • Michaeldc (Tue Aug 13, 2024 6:30 pm)
PostPosted: Tue Aug 13, 2024 9:14 pm
Building a 12 string with a Brazilian rosewood neck…
These users thanked the author Brad Goodman for the post (total 5): Terence Kennedy (Wed Aug 14, 2024 9:15 pm) • rbuddy (Wed Aug 14, 2024 4:30 pm) • Kbore (Wed Aug 14, 2024 9:32 am) • Hesh (Wed Aug 14, 2024 6:06 am) • bcombs510 (Tue Aug 13, 2024 9:36 pm)
PostPosted: Tue Aug 13, 2024 10:09 pm
First name: Jay
City: Bothell
State: Washington
Ooh, that's nice. I used to have a PRS that had a Brazilian rosewood neck and fretboard and it was a fantastic neck. PRS left it unfinished which I liked a lot. Also, the smell when opening the case was amazing.
PostPosted: Wed Aug 14, 2024 1:49 pm
That's actually a great idea. I might have to try that.
Users browsing this forum: No registered users and 42 guests
